Displays the configuration of one or all VPPs.
| vpp_name | Specifies the name of an existing local VPP. |
All.
You can only specify local VPPs with this command. If you do not enter a VPP name with this command, the command displays all local and network VPPs.
The following command displays the configuration of all VPPs:
# show vm-tracking vpp
VPP Name Type Value
nvpp1 origin network
counters ingress-only
VLAN Tag 200
VR Name VR-Default
ingress ingLocal1.pol(1)
ingLocal2.pol(2)
egress egrLocal1.pol(1)
egrLocal2.pol(2)
lvpp1 origin local
counters egress-only
VLAN Tag 100
VR Name VR-Default
ingress ing1.pol(1)
egress egr1.pol(1)
egr2.pol(2)
Number of Local VPPs : 1
Number of Network VPPs: 1
This command was first available in ExtremeXOS 12.5.
